cyclops222
- Mar 21, 2024
- 3,216
Can include ANY type of vehicle. Older the better.
If you ever do the conversion... please make sure the kit is using real GM ignition parts. (They're out there just hard to find) The modules in the sierra kits and the like are the same offshore crap available for the older HEI stuff and just don't last.Depending on if it's a car/truck or boat, carbs give you choices
Quadrajet
Holley
Carter/Weber/Edelbrock
even for the Quadrajet which has not been made in 30+ years you can get just about any part you'd need, as long as you have a good core and the throttle shafts aren't getting sloppy
Holley parts are everywhere and so are Edelbrock
if you have a pre-vortec engine you can use a simple/reliable Carter mechanical fuel pump that often lasts 20-30 years, no contacts to oxidize and cause no starts or stalling like with electric
points vs electronic, well points do require maintenance, but when they fail it's usually not total refusal to start or keep running rather gradual deterioration. With Electonic when the module quits no ignition.
I still have the OEM Prestolite distributor in my 4.3, I have a couple of spare Prestolite V6 marine distributors because the advance springs for these are NLA, but I have numerous sets, so no reason to change as of yet.
But yes I have thought of converting over to the Delco EST, by the time I'm done though with the distributor plus the updated ESA module to work with the OMC Cobra shift system I'm at about $650 for that.
that was exactly why I hesitated to do it!If you ever do the conversion... please make sure the kit is using real GM ignition parts. (They're out there just hard to find) The modules in the sierra kits and the like are the same offshore crap available for the older HEI stuff and just don't last.
And i bet you have a set of points in your toolbox on the boat.I will keep my 1990 Mastercraft that has a carb, and points. Have all the power I need and the simplicity is a bonus.
