Re: opinion on 115 mercury
Look under the flywheel and you'll see the stator. If it's red, it's been updated. If it's black, it's waiting to fail. Black ones have a very high failure rate. Update kits are around $400+. (RAPAIR replacements have the coils bare and not encased in plastic, they're fine.) Gearlube and water pump always on any used motor that's new to you. Fuel pump rebuild because they had some check valve problems, kits are cheap.
Yes it's oil injected, at least it came that way.
This you should be prepared for. It idles on the upper two cylinders and the bottom two kick in between 1/4-1/3 throttle. In that throttle range, it has kind of a hard time deciding on running on 2, 3, or 4 cylinders. It acts like it's misfiring and something's wrong. There's nothing wrong, they do that. It's hard to keep a steady speed for wakeboarders and beginner waterskiers. Other than that they're good running motors.
