HighTrim
- Jun 21, 2007
- 10,486
Hey Guys,
The previous owner of my Johnson told me he was overheating a ``bit``, lol, I think he was understating the problem. I changed the impeller today, and noticed that the rubber grommet on top of the impeller housing where the water tube slides in was shoved in the hole of the impeller housing, definately blocking any water from exiting. Figured problem solved....When I fired her up, seemed to cough quite a bit, ran her on the muffs at idle, just under 1000, for about 5 to 10 mins and noticed on the temp gauge she got quite hot, around 160 degrees, which is just under redline, so i shut her down, no warning horns or anything. Ive never had a motor this large, will running one on the muffs at idle create that kind of heat? I know that my t stats are suppose to open at 145, and as the engine speed increases water pump pressure opens the relief valves, allowing the engine to run cooler at higher speeds, so am i heating up since im not opening her up on the water and am on muffs? Faulty pressure valve or t stat? Does anyone use a Markal Thermomelt Stik on the cylinder heads to gauge overheating, apparently if a 163 degree stick melts on my head my engine is running too hot. ANy input by you pros would be great, dont want to take her on the water overheating , tks
ALso I assume I should re torque all my head bolts if it was running hot, 18-20 ft lbs.?Should my warning bell go off if i ground my heat sensor?
I also replaced the plugs with NGK BUZ8H, are these ok for this motor, could they be causing the coughing?
