Open ocean in a 21' bow rider, any direct experience?
cayman drew
I have googled this subject enough to know it is widely discussed and debated. Mostly I see people asking if it's safe to take a 17' - 19' bow riders out in the open ocean. My last boat was a Robalo 2440 and I'm well familiar with going off shore fishing in it, sometimes in big seas. My question is though, is it really necessary to use the bow cover on the new boat if I venture out of the bay? It just seems to me that my new 21' Four Winns H210 is plenty of boat for the small 1-2 seas I'd venture out in, without being concerned of green water over the bow? Does anyone have any direct experience with a bow rider of this size in coastal waters?
Willyclay
Re: Open ocean in a 21' bow rider, any direct experience?
What's the difference between a CC with an open deck that goes offshore or a bowrider with dual consoles and open bow? Seems to me there is very little difference. The major factor is weather conditions. Be safe!
cayman drew
HUGE difference. The offshore CC has a self bailing deck. If you stuff the bow into a 10' wave and get 100 gallons of green water on the deck it flows right out of the back ports by design.
A bow rider does not have a self bailing deck. If you take a huge amount of water over the bow you could be in big trouble. That one little bilge pump is not nearly enough.
However, that wasn't the question here ;) The question is how often boaters in 21' have actually gotten water over the bow.. From what I have read people suggest covering the bow rider with its bow cover to shed water just incase. I won't be out in 4-6 footers maybe 1-3.
mpsyamaha
Often times bowriders dont have quite the same hull shape as similar sized deep v center consoles do. But, for light seas Im sure youll be fine. Ive been in the ocean in many types of boats including a 4 winns that was a little bigger than 21 (cant remember exact size), it was a decent hull as I remember it. Just use good judgement and dont get caught real far from the inlet if the seas kick up, or it will be a long, slow (and probably wet) ride back. Also keep in mind that in a CC you can easily stand up and drive when things get rough... having to sit makes the size of the waves really matter more on your back!
mpsyamaha
Most newer bowriders DO have self bailing decks that drain overboard. The company i work for owns about 25 bowriders of many different brands, some outboard powered, most are IOs... and every single one of them has self bailing decks.
Bill3434
It shouldn't be a problem if you do proper planning and safety procedures. I've been on my local lake with 4 footers (Kansas gently breeze) in a 16ft tri-hull won't say it was fun ride but a man needs his fishing time; though the only thing I got on the last trip like that was increased boating skills.
Slip Away
The 2012 Four Winns H210 does not have a self bailing cockpit. The engine compartment dividers, storage area's under the cushions and bow storage is all lined with carpet. Not exactly considered an off shore set up.
Sure, you can go off shore in 1-3 footers in an H210. I have been in worse than 1-3 on lake michigan in an H180. You will not make any record time, but you can get where you are going. But if you do stuff the bow, plan on a week or two to dry all of that boat out.
cayman drew
Maybe we're getting our terms confused here. On all off shore fishing boats I have been on their are large holes in the deck or transom at the aft that allow water to pass direct through (without pumps). My bow rider is a 2012 and here's a pic of the stern:
There are definitely no ports to allow deck water to pass through nor are they on the sides. I just googled a ton of bow riders and can't find any self bailing decks. Perhaps you mean the decks drain into the bilge? That I would think every boat would do yes. However, this is WAY different and a little 500 gph bilge pump will not be very effective against a large amount of green water on the deck.
cayman drew
Thanks, pretty much what I thought. Do you think having the bow cover on would save that dry out time?
H20Rat
I'm thinking the same... Different terms... Just came from our local winter boat show, not a single bowrider had a self bailing deck. Probably looked at 30 different boats. If you stuff the front end of any of those, you are in trouble.
I wouldn't trust a bow cover to do much either. (put your bow cover on, now stand on it. That is the same as maybe 30 gallons of water.) It will keep the floor and interior a little dryer, but if things get really bad, it won't do much to keep you front stuffing the front end in and taking on water.
mpsyamaha
ok sorry, they all have drains in the deck, but whether they drain into bilge or overboard is two different things. I wasnt thinking, my bad.
if you plan on boating in the ocean in any boat, better make sure you have plenty of bilge pump just in case! my 17 footer has a 2000gph rule in it.
Slip Away
The bow cover will help with spray. May help if you stuff the bow, may not. As long as you are not getting soaked, the bow cover will help lessen the time to dry out the boat, if it gets real wet out there.
Chris1956
Gee, I took my 19 SR Bowrider into the ocean hundreds of times. I never stuffed the bow into a wave, and I have been out in 3 footers, and 4 footers many times. If you run into a 10 foot wave, you have some issues to deal with. You had better know how to ride it, as you will lose in a direct confrontation.
For the record, that boat did not have a self-bailing cockpit, but since I never took anything more than some spray and some wind-driven splash over the bow, it was never a problem.
Just so you know, the scuppers on self-bailing cockpit boats are not much larger than a bilge pump outlet. Therefore taking 100 gallons of water over the bow is going to be an issue for those kind of boats as well.
cayman drew
Thank you! That's the real world I was looking for. Google is great but sometimes too much information can drive you mad. Seems like everyone has an opinion on this topic and the more you read the more opinions you get..
Home Cookin'
I wouldn't rely on one guy's ability or luck to be your "real world." We don't know his hull or skill, load, whether his "3 footers" were broadly-spaced swells (no problem) or cross-running chop on a current adverse to the wind (big problem) and for how long.
What concerns me is your question (and accepting an "iffy" answer about the bow cover. Bow covers should NEVER bwe relied on for safety as if they are a deck. They are for comfort, and while they will shed spray and light water, your bilge pumps would probably handle that. But there is a high risk that they will collapse under a big load, as well as come unattached--a real problem in high seas no matter how good you are at snapping it on at the dock.
"Open ocean" can be a lot easier than an open shallow bay or an ocean inlet.
"bow rider" could be a boat with bow seating--irrelevant in many respects to seaworthiness; the important aspect is the shape of the hull. Sea Hunt's dual console is a bow rider--with a seaworthy hull. My old Starcraft bowrider made it through all kinds of bad stuff; it had a good design. The same size Bayliner-type boat is a design failure in this respect, and highly dangerous IMO. Even Bill's 16' trihull is safer than your bowrider--so his recommendation does not answer your question; it just supports your false hopes.
Willy says "What's the difference between a CC with an open deck that goes offshore or a bowrider with dual consoles and open bow? Seems to me there is very little difference. The major factor is weather conditions. Be safe!" Not so. The difference is in the hull shape. Once conditions get bad, the difference is a matter of making it. In fair conditions, the difference is irrelevant.
However, you said "new 21' Four Winns H210 is plenty of boat for the small 1-2 seas I'd venture out in." I think you are right, which may surprise those who know my opinion of sofa boats. You would do fine in those condtions, and the "lots of bowriders off shore' do fine in those conditions. The issue is what happens if the conditions change? if you are close to sheltered water and know how to spot weather changes, you are fine. Commit to a long distance with unstable conditions, and you may be in trouble.
All boaters have stories of taking a too-small boat out in too-big waters and making it. Those stories are NOT good answers to your questions or "real world." Else I'd recomment a 15 year old taking a 14' wooden row boat with a 9.9 out jumping 4' swells in an ocean inlet with ripping current, uncharted bars, no boats around, no radio, no pump, before cell phones. Worked for me.
DBreskin
My 1992 H200 has a pretty high bow compared to other bowriders I've seen, especially the Yamahas. Even so, I've scooped a wave in 2-3 foot waves in Chesapeake bay. Fortunately I only took in about 5 gallons.
I've run with my bow cover on to keep the wind and spray out but I'd bet 100 gallons of water over the bow would tear out the cover in seconds. In the event the cover held, the water would just come over the windshield and into the cockpit anyway.
smokeonthewater
with a skilled captain and a running engine no it isn't..... hell it's only the weight of 3-4 people and an inch or two deep... it runs out the back in a minute or so...There are plenty of cases of boats like my lil v-20 taking enough over the bow to be over a foot deep and powering out as 90% washes over the transom and the rest drains through the scuppers... Btw My scuppers are 1.5" inside diameter
with a sofa boat it goes to the bilge and with an I/O it doesn't take a whole lot to flood the starter putting the battery positive under salt water possibly shutting down the electrical system and thus the engine..... can go from fun to scary really fast
Tail_Gunner
Yes that last sentence says it all..one good stuff and down she goes. And a bow cover will just collaspe
