ooops 40 hp super seahorse
alex1963
model # RDSL 22 serial # 2032369 same info on this engine is what I need help with year and spec and float setting thank you Alex
Vic.S
Re: ooops 40 hp super seahorse
RDS-22, 40hp, 1960 I guess RDSL is the longshaft version
Floats usually set with the top parallel with the top when the valve closes. Someone will say if this is different.
alex1963
thanks another question or 2 if ya dont mind mag. to flywheel gap setting? and.018 on the points right? fuel mixture thanks for the help Alex
rolmops
Unless you really want to create a smoke screen you should run that engine at 1:50 because that is what they are supposed to be run on according to Evinrude /Johnson OMC.
