Re: Only starts as I let off the key.
So should I use a meter to check things out? Where do I put the meter? What readings should I get?
Also someone has installed electronic ignition but looks like they used the old coil setup. Do I still need the ballast resistor with the electronic ignition? I keep reading that electronic ignition needs/works with full battery power all the time since there are no points to burn up.
