Re: Only one side will spark
Occasionally a plug wire will become faulty under the armature plate which will allow it to short out to the bottom of the armature plate. However, you've stated that you have replaced both plug wires which would eliminate that possibility.<br /><br />The coil metal yoke, the vertical part of which must align with the inside bevel (on the armature plate) that you see where the coil sits upon the armature plate. This sets the coils at the proper distance from the flywheel magnets.<br /><br />Possibly one plug wire is slightly short at the coil end which would prevent it from engaging the coil prong properly. The only other think I can think of is as follows:<br /><br />(Magneto Armature Plate)<br />(J. Reeves)<br />If the armature plate has a a loose fitting, wobbling motion (the plate that the points, coils etc are attached to), it is usually caused by a slightly worn support ring. This allows the point setting to change erratically as the armature plate turns.<br /> <br />The cure is to remove the armature plate so that the support which is attached to the powerhead with 4 screws is visible. Then, with a screwdriver and hammer, or some tool of your choosing, and looking straight down at the support ring, make an indentation at what would be called the 12, 3, 6, and 9 O'clock positions. Install the armature plate and check for a smooth turning wobble free movement.<br /><br />You may need to do that procedure a few times to obtain the proper fit (not too tight, not too loose), but it's worth the effort.
