I had made a thread a couple/few weeks back, but have done somethings since then. Here goes.
I have a 1988 force 85hp on a 17' bayliner capri cuddy. I can only get 4200rpms out of it. I have replaced fuel pump and cleaned the screen. Checked and adjusted mixture and timing. I have made sure that the butterflies are fully open at WOT. Compression from top to bottom is 125, 125, 130. I do not have any help at the moment and do not have anything to ground the plugs, so I verified spark with the timing light a idle. All three were blinking. It runs great. I have the boat on a slip on a river and after cleaning the bottom it would get to about 32-34mph on a speedo (I know its not accurate). I am not so much worried about how fast I am going as to how well the motor is running (optimum rpm range)
Just today I rebuilt the carbs. I was sure it was the carbs because ALL the floats were out of adjustment and the bottom one had quite a bit of sediment in it. As you probably figured out because I am posting this, I am still only getting to 4200rpm.
Where do I go from here?
Thanks,
Joe
P.S. prop is new and a 13 X 17 pitch
Thanks,
Joe
