bowhuntrrl
- Mar 26, 2003
- 320
History: Boat and engine sat over 4 years 1986 DT-85
Upon purchase, so far I have rebuilt the fuel pump, replaced fuel pump o-ring and fuel pump block o-ring. Removed and rebuilt all 3 carbs, readjusted the choke solenoid for full pull, checked float levels. Checked compression: 130 lbs +/- 5 lbs . Replaced the plugs with NGK B8HS. Rebuilt the water pump. Emptied out the oil tank, cleaned and replaced oil with new synthetic blend. Checked the oil pump timing/adjustment. Replaced water separator filter with new and connected an external plastic tank with fresh 50:1 mix of 89 octane.
The Problem: After the above work, it ran fine on the muffs. Took it to the lake and it immediately fouled the top plug. Cleaned the plug and moved it to middle cylinder and restarted it. This time the middle cylinder fouled. Thinking it was a bad plug, replaced it with a new one. Took it to the lake. It started fine, but boat wouldn't plane, running on 2 cylinders. The problem appeared to be a fouled plug in the middle cylinder.
Took a trip to the auto parts for another plug, this one a BH7S (just to test). Took boat back to lake. Now the boat would not start. I cranked and cranked, and choked and cranked. All plugs were dry !! Took it back home. The bulb was pumped up hard, there was fuel in all the bowls, and the choke is closing tightly. Fuel does not seem to be sucked into the cylinders. Engine has a nice blue spark when cranking with plugs grounded, carbs have fuel in the bowls, and engine has good compression. Finally got it to fire after a lot of choking and cranking.
What could the problem or problems be ??? Can idle adjustment be the cause?? I've had it from 1 1/2 out to 2 1/4. It idles faster and better when leaner and rough and smoky at 1 1/2. Can I possibly get that many defective plugs??? I seem to remember real bad luck with NGK plugs and snowmobiles from the past.
