Re: One more question. Two wires hanging loose
everything seems to work. I still got some sorting out to do under the dash. The trim gauge and the fuel gauge was'nt working and someone had took the purple hot wire off the trim gauge to hook up a depth finder so I spliced the depth finder and hot purple wire with a ring terminal and hooked it up to the trim gauge and the fuel gauge started working with the trim gauge. While I did that everything that was working on on the accessory switch all of a sudded worked with it off. So I have to figure some more things out. I did notice that the courtesy light on the outside of transom that used to work before the mechanic pulled the engine doesn't work any longer. I used to work while navigation lights were on.
