I am attempting my first bellows change on a alpha one gen 2. Using manual #14 as I guide I see it never mentions what to do with the gear lube hose. It seems like it has a high chance of snapping the threw transom connection if not cut right away.
So if I understand correctly I should cut the tube before I even start taking bell housing off. So for reassembly I plan to use a knife and cut the tube off the gimble housing fitting and use new tube from fitting to bell housing. I assume this is better then the trying to pull it off the fitting. I don't know what the bell house side looks like but I assume you can get in there to reattach that end.
Lastly my goal is to replace all rubber in that area to avoid doing this again until bellows need to be replaced again. Is there anything else that should be replaced like the water fitting threw transom and tube fitting threw transom.
Is the loctite and primer still recommend as in the book.
Replacing with OEM uni bellows, shift cable, cable bellows, trim senders, water and lube tube. Sierra exhaust bellows.
Thanks.
Thanks.
