Re: One cly. blues..
Hi there and thanks for the reply. I went through the carb and it is as clean as can be-this is what I thought the problem was at first. Found out it is an electrical problem and the bottom cyl is not getting spark. I know both plugs and plug wires are good cuz I swapped them with the top cyl and it still ran the same. I relpaced the coil and that didnt solve it. I figure it must be the power pack, but how do I test it to see if it is good or not-instead of buing a new one for $80 and hope it solves the problem? Any suggestions? DJ<br /><br />PS-I have good compression in both cyl.
