Re: on watess now need advice getting interming alarm like oil warning.
We are back on shore now. The beeping stopped on it's own. It was a oil warning type of beeping, not a solid over heat alarm. I did check to make sure the tattle tale was flowing well and I could put my hand on either head. It was not too hot.
When it was beeping, it (the beeping) seemed to vary a bit with me changing RPMs. I wonder if there is a fuel restriction alarm?? I have dual tanks and had been running on one, I switched it so the engine could feed off of both at once. After doing so, the beeping stopped. The first tank I was running on does have an anti siphen valve, the second tank does not. Could the valve be sticking and restricting flowand causing the alarm? I did not think to check if the fuel bulb was collapsing.
At no point did the engine drop rpms, which would point towards a fuel issue. I was only running as high as 2300 rpm at any point though, I did not push it any faster, Any thoughts? Thanks, Scott
