GreatRiverDucker
- Jul 12, 2007
- 133
Ok men here is the story. I've posted about this motor before but for different problems. It is a 72 evinrude 25hp Sportster long shaft. We bought it from a guy who said it ran but probably needed a tune.
So the first trip to the water went like this, it started ok, but when we opened it up it slipped out of gear. We took it to the shop, and the guy flipped the clutch dog around.
Well when I took it out the second time, same problem, slipping out of gear. Took it back to the shop, the guy put a whole different set of gears from an older motor in it, he said that they were slightly different, but that they would work.
This time on the water it was having trouble getting fuel. Went through fuel line from tank to motor, switched to new line, was slightly better for a little while but then had more problems when running in the tank. So I took the fuel pump off, disassembled and cleaned it, put back on. Then while running it in the tank I sheared the water pump pin. So I had to replace the whole water pump.
Whew, so third time on the water it started, backed up, but when I put in forward and gave it throttle it started to bog down and then died.Then it would backfire when restarted. Note that it didn't die when in reverse.
So at this point I was getting really frustrated.
Ok so then I sought your help, and checked comp(approx 120 on both), and spark good on top cyl (7/16") not so good on bottom cyl ( maybe 1/4" but intermittently) so I thought it was probably a bad coil but didn"t have time or tools to pull flywheel. So back to the shop it went. The guy checked the coils , said they were fine, replaced a vacuum line that he had previously patched, and replaced the fuel pump.
Fourth time on the water. It took a long time to start but finally it backfired and started. It seemed to be running well just a little smoky. So we started down the lake slowly up to plane. Then lots of smoke and it lost power and died. Back to the shop.
This time the guy says that it overheated, because the water pump pin sheared again. And that the pistons were scored and now comp is only 75.
ARRRGGGHHHHH!!!!
Ok so basically I'm wondering if there is any hope for this motor, if so what to do, or if I should turn it into an anchor. Also does anybody have any clues as to what the issues were?
ARRRGGGHHHHH!!!!
