Guys,<br /><br />At your suggestion, I'm looking at an on board battery charger. Since the prices really vary, can you tell me what you think of this one at Cabela's? (Only $81, any good??) I'm only charging my trolling motor by itself. <br /><br />THANKS in advance!<br /><br /> <br />Storefront > Marine > Boating Accessories > Battery Chargers / Components > Guest Charge Pro On-Board Chargers > You are here: Guest Charge Pro 2608 On-Board Charger <br /><br /> <br />Guest Charge Pro 2608 On-Board Charger Item: IC-013299 <br />Price: $81.99 <br /> <br />Qty: <br /> <br />Guest Charge Pro 2608 On-Board Charger <br />Charge-Pro charging systems feature components completely sealed in waterproof thermal epoxy to prevent damage and corrosion even when submerged or during rough rides. Units have three-stage charging cycles for fast recovery, overload protection with automatic resets, LED lights to indicate charging status, and Smart technology that prevents battery damage even when the charger is left on. The Model 2608 Single Bank charger is 6-amp and can be permanently mounted on your boat and measures<br />6-3/8"L x 2-1/16"H x 3-1/2"W. Can be left on for maintenance during storage. Use 12-volt systems. Charger also accepts the 10-ft. wire extension for connecting a starting battery in the stern of the boat. <br /><br /> Receive a $10 Cabela's Bucks rebate coupon with each charger. Use it just like cash on your next order from Cabela's. Coupons expire 12/31/01. <br /><br /> <br />Back to Guest Charge Pro On-Board Chargers
