Hi,
I have an older (6 or so years) Bass Pro Shops 5/5/5 on board charger. It has worked very well, but recently "lost" on of the trolling motor charging circuits.
Before I run out and buy a new one, I am wondering if it would work ok for me to switch the cranking battery circuit with the "bad" TM circuit and still work ok.
I am not overly concerned with not getting a full charge into the cranking battery. I am just not certain that this will work ok because the cranking battery wires are clearly marked, suggesting to me that there might be a problem of some kind hooking it up to one of the TM batteries.
If it makes any difference to the answer, I have two TM batteries wired to provide 24 volts.
Thanks in advance,
Jeff
Thanks in advance,
Jeff
