I just bought a 2004 Bay Craft flats boat. I came with a west marine wall mount battery charger that plugs into the side of the console using an extension plug. it seems to be only running up to the front trolling motor battery and this is where I'm confused. .... under the console the plug has 2 red wires and 1 black wire. The two red wires go into the transformer looking thing which I still haven't figured out what that's for but one goes to the front of it and the other to the side which then go to the battery (the two red wires are the two main terminals on the plug) Now the black wire (in bottom ground position on the plug) goes up towards the battery and is just hanging there. It seems to me it should be connected to the battery and the guy I bought it from has no idea. but when I connect it I can hook up my multimeter and get 12 volts at the plug on the console. Ive taken the boat out twice and had the charger hooked up and it seemed to charge because the little green light said its ready. but I'm not so sure whats happening with that ground wire not on the battery.
I would love any kind of help so thank you in advance
Jason
Jason
