OMC VRO Fuel Pump Problem?
CoopDog
I have a 1985 Evinrude 90 h.p. VRO. The VRO system has been bypassed. The motor still has the VRO type fuel pump but the oil inlet is plug and the electical connection is disconnected.<br /><br />I am having a fuel starvation problem. I have replaced the fuel tank and fuel line, so that is not the problem. I have checked the fuel filter in the engine. That is not the problem. Next in line is the fuel pump. How do I check this? I have no service manual (although I have ordered one). If the fuel pump is bad, should I replace it with a non-VRO pump? I don't mind mixing oil in my gas and want to save $$ on the repair.<br /><br />Coop
Terry H
Re: OMC VRO Fuel Pump Problem?
Alan...you might remove and clean/check the pulse limiter...look at your manual for instructions...just a Thought
