OMC vhs timing and linkage adjustments
That old Mercury
Cam across this on utube, they are original vhs videos from omc.
I did not copy the link because it takes you to a persons utube channel.
Yes i know you will still go to the persons utube, but its up to you if you do!
But here is all you need to type in the utube search bar.
For your motor
OMC 1987 and newer 3 cyclinder linkage adjustments.
OMC 1987 and newer cross flow V4 linkage adjustment
Linkage adjustments 1988 and newer loop V4 and V6
