Boomyal
- Aug 16, 2003
- 12,072
Both the Seloc manual and an OMC parts catalogue refered to an oring to be installed with all the various washers, tension washers, bushings, clips yada yada yada.<br /><br />The oring is not pictured in the Seloc manual, I don't remember in the OMC parts breakdown where it went and I don't remember seeing one, or remnants thereof, when I pulled the thing apart a year ago.<br /><br />Any input here? I'd even be humble enough to accept it from any of you OMC un-appreciators. <br /><br />Incidently, the forward steering shaft bushing, which is a flimsy little nylon bushing, is no longer serviced. I probably could have reused mine but it had a corner breaking off the the split part. Luckily a local boat shop had 5 in stock.
