OMC Touch Trim to Power Trim
robban
I have a Johnson 50hp BE '90 (short leg). It´s equipped with a badly working tilt system called "Touch´n Trim". The system is supposed to help you trim the engine without stopping the boat, but it really doesen´t.<br />I´ve been told, that the TT and the Power Trim system both use the same hydraulic cylinder. <br />Is it possible to rebuild the TT system to a real power trim? In that case, what do I need?
seahorse5
Re: OMC Touch Trim to Power Trim
The tilt and trim and the manual trim are completely different cylinders, nothing is the same. The tilt and trim kit will bolt right in, though, but it is not cheap.
robban
No, it definitely isn´t cheap. I called my local OMC dealer, the complete power trim set for models from '89 to '95 goes for around 2,200€ here in Finland (about 2,500 in US dollars). As a brand new 50PL costs around 4,600€, you could say that one half of the engine is trim&tilt.... WOW!
