cerikson3698
- Apr 8, 2008
- 30
I have a 84 70 hp rude with OMC controls. I believe my problem is with the controls but not sure. When the throttle is all the way down we only go about 5 mph when we used to do about 30. The throttle will click into idle but not go into idle, then when we pull it back more it just jumps straight into reverse. Sometimes it will idle really really fast and then when we put it in gear it will give a hard jolt but then like I said will only go about 5mph. We can temp fix the problem by pushing the throttle back and forth from froward to reverse. But it always comes back. Do I need to replace the entire control unit and if so would a mercury one be compatable. This is the one I am thinking of purchasing if I need to buy a new one, but not sure if it will work.
Controls
Thanks
Controls
Thanks
