Double J 300
- Jul 1, 2007
- 10
Gave my son a 1999 Johnson 115 low hours as I got it new. I used to be an OMC tech. The motor appears to go into SLOW (2500 rpm max) for no apparent reason intermittently. Temp gauge stays at cool, no horn or system check light. I had a new power pack and had him install it...same effect. Could it be a bad overheat sensor for SLOW (white wire)? Anyone see this before? Can the SLOW sensor be disconnected to end this? The tan wire will still sound the horn and system check light, correct? Motor is immaculate, all grounds as new. Did it for me only once when I had the motor two years ago. Thanks, Alan
dblej@tampabay.rr.com
