BLDFW
- Nov 1, 2008
- 121
I'm in the process of resealing my outdrive and have hit a stumbling block and am not sure how to move forward so I'm soliciting opinions from anyone who's worked with an OMC stringer waterpump housing.
Badman, that includes you!
Please see the attached pics. The water pump housing has a male component which slips down into a female component containing two rubber seals and a 1" band of gasket like material. The gasket material fits into an aluminum sleeve that slips down inside the swivel housing. The two rubber seals fit above and below this sleeve.
To replace the lower rubber seal, the upper seal and the aluminum sleeve have to be removed. I need some insight as to how to remove that sleeve without damaging the cylinder walls it slides down into.
Any insight or assistance you can provide would be appreciated.
Thanks!
Thanks!
