1985mazdarx7
- Jul 25, 2004
- 9
Last year my Dad and I replaced the floor in our 1977 Starcraft SuperSport 18. It is a long story but basically what happened was the boat was parked for three years unattended with the drain hole plug in at the bottom of the transom and after several snow falls and rains the hull collected with water and the tilt motor got full of water and corroded. So simple enough, it isn't the first time the tilt and/or trim motors have corroded and stopped working so it wasn't the first time we have removed and rebuilt or replaced. The problem is when we put the tilt motor back into the boat the leg (or whatever the pros call it, thing with prop attached too) fails to lift up when the motor is engaged. We get the solenoid clicking and occassionally the motor will spin but there is a not so great grinding coming from the rear (again I don't know the exact names) where a worm gear comes through and is attached to a shaft from the tilt motor. The worm gear is grinding on a brass gear in another casing right below where the worm gear comes out. This brass gear is slid in on top of some type of clutch system in that same casing. Now I don't know why first of all the worm gear is grinding, obvisously it isn't meshing to well, but both gears, (Worm and brass) look like they are in good shape. Plus, the leg can be lefted by hand even when all gears and the tilt motor are put in place. One of my questions is what is the purpose of this clutch system, it is composed of about 10 or so discs that compress together. When we took them out they had oil on them. I know that casing is full of oil but doesn't a clutch with oil on it slip? However, there is something obviosuly wrong with the way we have put this whole tilt system back together that is causing the worm gear and brass gear is grind together, and then eventually they jam (which isn't good for them). And also, could sometihng have happened to this clutch system.. say like does it have to be compressed with some type of tool so it doesn't slip or something.. We have no idea what's wrong but really don't want to take to a dealer, partly because we don't have one in town since OMC went under and a repair shop is questionable as they will milk this problem for all it's worth and charge alot of money I will guess. Someone, please give me some tips on what is wrong and something I can do to fix it. <br /><br />Also, could someone tell me the displacemnt of my inboard GM 4 cylinder engine. It says it has 140 horsepower. Is it the 2.5L? Anyway, thanks for any tips or help leading to fixing my tilt problem<br /><br />- Jeff
