Re: OMC Stern Drive U-joint type gearing??
Lyndon:<br />Those are called ball gears and some wear is normal. I have no idea how to replace them, but I don't think it was major operation. I'm pretty sure it required tearing down the outdrive which probably will take it out of the DIY category. Seems like OMC used lots of special tools.<br />One thing that is very important with the old OMC ball gear units is not running the outdrive in any sort of up position. Many people used to run them at idle in a slightly tilted position for shallow water. They then forget to put the oudrive down, destroy the ball gears and usually wreck the entire lower unit.<br />I had a V-8 Chevy OMC for 18 years that still had the original ball gears with very little wear on them when I sold it. I did NOT run the outdrive in a tilted position, period! I think that is the reason I never had any ball gear problems. Find yourself a mechanic that is familiar with the Older OMC's and keep him happy. They had their quirks, but like I said, mine lasted for 18 years and as far as I know might still be going. <br /><br />Charles
