Re: OMC Seadrives Repair or Replace
I have replaced the seadrives on a few boats with a bracket .You can buy used midsections,and use your existing powerheads and lowerunits(assuming they are in good shape)and convert to standard outboard.The conversions Ive donewere on single applications.But ,Ive seen many wellcrafts and hulls with full transoms retrofitted using brackets .The owners are more than happy with the performance.You will need to fill in the various holes in the transom,but its not something that is hard to do.Stainless Marine in South Fl. has a website that gives info.They custom make brackets.There are other manufacturers as well. Perhaps in North East.If you go with converting your engines,.you can use your current controls,the cables might also be long enough.If you like your hull,its a great idea.Good Liuck.
