omc rpm meter
flortje
Joe Reeves <br />OMC Guru <br />Member # 6826 <br /><br />help me :confused: <br />i fryt my omc rpm meter i need diagram or print foto from the component's to recognice resistand collor en replace it <br /><br />thanks<br />didier.dutrieux@pandora.be
Joe Reeves
Re: omc rpm meter
I'm not sure of what you're asking me, however I think you want to know where the various colored wires of the OMC tachometer would connect to. If so, the explanation follows.<br /><br />Black = This tachometer wire would connect to any ground.<br /><br />Red = This would connect to your light switch. Voltage to this wire illuminates the tachometer for night viewing.<br /><br />Purple = This is the 12 volt source to the tachometer. Connect this wire to a source that would apply 12 volts ONLY when the ignition key is turned to the on position.<br /><br />Gray = This is the tachometer sensor wire. There should also a "gray" wire extending out of the engine instrument cable at the console if you are using a binacle control mount.<br /><br />If you're using one of the white OMC control boxes, it may be one that has a three (3) socket connector just below the ignition switch. In which case, those sockets consist of a black wire (ground), gray (sensor), and power (12 volt), configured as follows:<br /><br />.......Gray(sensor)<br />...........o<br /><br />......o.........o Black(ground)<br />.. Purple<br />...(12v)
flortje
Re: omc rpm meter
its a lcd quarts rpm meter from omc (on back 16 fm) with four wires purpel,gray,black,blue<br />i now the conection but its broken end i need a foto from inside or a layout of the print with components on it just need foto from inside of a working one to see the collors of transisters becorse i dont see annymore to have burnd out so its posibel for me to replace them en repaere the rpm meter.<br />look at profile for mail adress for send foto of inside rpm meter<br />sorry for my rayting bat im belgieum en do my best<br /><br />thanks
Xcusme
Re: omc rpm meter
Joe, <br />I think the gentleman is asking if you (or anyone)have a picture of the insides of the RPM guage. I gather he's looking for the resistor values of the various parts as his are burned beyond recognition.
flortje
Re: omc rpm meter
thats it , so this is wat i needs ,plaise help me :confused: :(
OBJ
Re: omc rpm meter
Hi flortje.....<br /><br />Generally speaking, schematic diagrams don't come with the gages. Nor are they included in service manuals for the engine. You may want to try the manufaturer and possibly get some help from them. Do you know who made the gage?
flortje
Re: omc rpm meter
made by omc hong kong if have good one to take picter its ok only need ref. from transistor's
