I am new to boating and have purchased a 98 maxum 2300sc boat. the boat need lots of tlc but the engine and outdrive seemed to be running fine.Engine is a 302 5.o HO with omc cobra 1993 model i believe. Had the boat checked out by local mec. and was given the following info..Outdrive oil looked good no water no metal. prop was the wrong pitch for our area 19p we are at 6000 feet(lake Tahoe) wants to put a 14p on.
motor runs great but controls are a little sloppy.
I wanted to test out the boat before taking people out on the lake. I was not able to get above 2600rpms and only going 12mphs then after 1hr outdrive had a problem where it sounded like a gear stripped and engine rpms jumped to over 4000. I was on top of the controls and was able to back off the gas. Engine is fine but had to be towed in. no foward but did have reverse but did not want to see how far reverse would go and shut it all down.
This engine and out drive is not oe. 5.7 with a mercruiser is the correct engine and outdrive. with current problems and looks like a purchase of a outdrive can I go back to a mercruiser using the 302 or do I have to replace motor and outdrive. What about transon plate will the mercruiser plate be close to the same size? I was told that the transom may have be cut to fit the omc drive. Or is it all not worth the problems to flip it back out?
thanks Ed
Thanks ED
thanks Ed
Thanks ED
