OMC Power Trim will not lower
jeffery57
Hello, I have a 70hp Johnson outboard with an OMC Power Trim. It raised but will not lower. The electric motor runs while trying to lower but it will not move. any advice or suggestions are appericated. Jeff
JB
Re: OMC Power Trim will not lower
Hi, Jeff.<br /><br />That is usually a sign of low fluid. Pull the filler screw (looks like lower end drain screw) and top her off. Cycle her up and down a few times and repeat until it wont take any more.<br /><br />Good luck. :)
jeffery57
Thanks JB,<br /> That was the problem. silly me, I thought if it were low on fluid it wouldn't raise either. Thanks again, Jeff
