I have a set of 1989 OMC controls hooked up to a 1989 Evinrude 120 HP out board. There is a fast idle lever on top, a deadman/safety kill switch on the side and keyed ignition switch at the back. My questions are these:<br />1. Below the keyed ignition switch is a black dial type switch (about one inch in diameter), which can be turned clockwise or counter-clockwise. What does this switch/dial do or control?<br />2. Below the above mentioned switch/dial is a 'black rubber plug' with two wires coming out (red and white I think). What is this device? Could it be the ignition beeper/siren?<br /><br />I was looking through the manual that I have for a picture with an explanation but the closest I could find was a wiring diagram which did not clear things up. Any ideas would definitely be appreciated.<br />Cheers<br />Mike
