Omc lubricant
Spectech
Hello I just purchased a 1982 sea swirl with an omc outdrive. I would like to know the best gear case lubricants to use.
Thanks for any help. If it matters it has a 3.0 4cyl
southkogs
Welcome aboard:
Pick your fav HERE or whatever the local shops around you have - I typically grab 80 w90 Gear Lube from the local WallyWorld. You don't need Type C in your lower unit (in case anyone suggested it).
