Re: omc lube type and qty please!
If you are sure that's it, that is an OMC Cobra, not the earlier stringer (usually painted white, big rubber gasket in transom of boat). If so it is probably a 1986 not 1976. <br />They are drained from the lower hole on the lower unit, and filled not from the lower but the hole just below the cavitation plate, until the dipstick (screw in the middle of top cover) reads full. It should take about 64 oz of OMC his vis or HPF gear oil. Make sure you fill it right (slow to avoid bubbles) or you will toast the upper gears! When filling, just put the dipstick in (don't thread in) that allow a little extra to make up for any air. Then thread in the dipstick plug.
