omc impeller location
Floorman50
Howdy folks , I just got this boat and ran it with muffs in the driveway and it worked fine, but then put in the lake , taxied at 5, and got out , gave er the gun and it started clattering like a diesel, meaning, extremely hot, turned around and coasted to dock, I know that sound, I'm sure the impeller is gone and water pump isn't where it usually is. Can anyone send me an exploded view of a 2.5 omc stern drive so I can avoid going on a wild goose chase , I would be so grateful to get a direction to go. I suspect it's half way to the prop, am I correct?
bruceb58
You should post more info like your model/year. Since you have a 2.5, you have a stringer drive and yes, it's in the drive.
