OMC Iginition interupter switch
earnies2
has any one replaced thies switchs with after market or generic ones if so what part #s did you use? I plan on replacing mine and before i do all the recherch maby somwon already has the info THANKS
Don S
Re: OMC Iginition interupter switch
WHY, are you wanting to replace them? Are you sure they are bad? They don't go bad very often.<br />Many times people ask questions similar to yours but it ends up that wasn't the problem to begin with.
Boatin Bob
Someone found out previously that they were made by Cherry Co., here is a link to the switches he found and ordered and saved a lot of $$$. As Don said though "Are you sure it's the switch"? Easy to meter and check before replacing.Cherry Switches
rbezdon
Just for your info, Cherry made the switched for OMC so these are "the real thing". I used this link and bought the swiches a couple of years ago.
