omc idle setting
full stringer
hey guys i have an 1984 omc stringer 800 full mechanical shift the boat is a sea ray express cruiser with a v-8 5.7 litre motor my question is what should the correct idle rpm be in nuetral. I have been reading to tie the boat off at the dock put it in gear then set idle at 650-800 rpms after full warm up others say 650-800 in neutral after fully warmed up anyone know for sure??
Re: omc idle setting
Ayuh,... In Gear...
full stringer
so if its 1000 rpms in neutral but around 650-800 in gear that is correct?
