OMC Gear Shift Inturupter Switch
Old New Guy
I have an older 71 Century TRI hull Stringer. She's Stalling in Netural. I looked hard, but I cant locate the Gear Inturupter Switch to check it. A little help please. Old New Guy
bruceb58
You won't have one because your drive is an electric shift.
Old New Guy
Thank you Sir. Makes sense now. What should I be looking for or at to fix this issue. Any suggestions?
southkogs
I'd be looking at idle adjustments. Though with an Electric Shift, you can't start it unless it's in neutral ... so what's happening overall?
bruceb58
Have you done a tune up...spark plugs, cap, rotor, points, fuel filter and points and set the dwell with a dwell meter and timed the engine? Once you do that, then you can start investigating things like the carb.
