somthing weird, im in the process of replacing the lower gears on my omc outdrive, which has been jumping out of gear momentarily when under a load. i got it apart today, the fwd and reverse gears look ok, maybe a little wear but the clutch dog on the reverse side is wasted. i have no experience on this but if you judge them on a scale of 1 to 10 with 10 being the worst the fwd end is a 3 and the reverse end is a 10. im still trying to locate a gear set, but if i feel the gears are allright why couldnt i just replace the clutch dog, any thoughts, comments or suggestions will be appreciated mickey1
