OMC fuel tank compatible? Issues with hose connecting to tank
Cassiopeia
I picked up a used OMC 5 gal fuel tank. I have 2 fuel lines, an older one where the fittings will only fit my Enduro's fuel fitting and the fitting on my older Yamaha brand plastic tank. And a newer fuel line where the connectors have a "notch" in them. This one also works fine on my Yamaha tank. This line "appears" to fit on the OMC tank, but it doesn't appear to seal, as when I squeeze the primer bulb it only seems to suck air. Is there something different about the OMC tank fitting?
