jmeydenbauer
- Sep 21, 2003
- 47
Can I use a regular Ford 351 truck motor intake manifold gasket on my 77 OMC 235HP motor or is there something special about the gasket that I should use one designed for the OMC?
Why do you suppose it is not needed, Seahorse?Originally posted by seahorse:<br /> The exhaust crossover passageway in automotive gaskets are large to keep heat under the carb. In marine applications, that is not needed and factory gaskets just have a metal restrictor plate with a round hole in them.
