Re: OMC flusher...
The flush kit I have is a replacement plate at the tilt. This is what my Seloc Manual shows for the flush.<br /><br />Now, my motor also has a Prestone flush kit attached to the hose from the intermediate housing to the thermostat housing.<br /><br />For the life of me I can't see why I don't just attach the hose there instead of at the tilt plate thingy. It seems that the water is going to flow the same either way.<br /><br />If no-one disagrees with me (and I am not sure I'm right or have even explained it well) then I would just get a flush kit adapter, cut the hose from the intermediate housing and flush it there. Be a whole lot easier then having to pull the plate off, put on the adapter, flush etc. then pull off the adapter and put the plate back on. Plus it'll be way easier on the gaskets.<br /><br />In case you can't tell, I've been thinking about this a bit lately as I plan to run my boat some over the winter and want an easy way to winterize it.
