I have a 1998 70HP Johnson 3 Cylinders outboard.
I need to get a new Tach as the boat came without instruments.
I saw on the Evinrude site that the Tach with system check is part number 0176301.
I found two Tachs with system checks that are suppose to be compatible.
1. FARIA TCK002A OMC SYSTEMS CHECK BOAT TACHOMETER
2. TELEFLEX 58883F BOAT TACHOMETER w/SYSTEMS CHECK GAUGE
I also found this one:
OMC 176307 BOAT TACHOMETER GAUGE w/ SYSTEMS CHECK
But having a different Part # i suspect it will not work for me.
Does anyone knows which one of this will actually be compatible with my 1998 70HP Johnson 3 Cylinders?
Any suggestions about other brands/models will also help.
