OMC Twin 4.3's starboard manifold runs cool to the touch at just over 3000rpm<br />port runs hot? same RPM not hot enought to burn your hand but hot enough so you can not keep your hand on it?<br />Both motor T stat housings feel the same and the gauges indicate the motors are being cooled OK but I am concerned re the exhaust temp.<br />Cooling lines to the manifolds are cold to the touch (Same on both motors)<br />When idled to 900rpm exhaust cools down Ok is this a problem?
