water_rat03
- Feb 25, 2008
- 58
I have a chance to pick up a boat for next to nothing. Here is the problem with it.
The shift cable broke. The owner removed the drive and started to replace the shift cable. Found out how much a new cable cost so he put the boat in the garage for storage. Over the years he moved, and now he thinks he lost some parts. He is not sure what all parts might be lost, he has 3 boxes of parts laying in the boat.
The boat is a 1985 with a 170 hp OMC, not electric shift.
I have an outdrive off of another boat, not sure what it is exactly. It is from somewhere between 1972 and 1975, 6 cylinder OMC.
Will any of the parts off the upper gear case fit the 1985 drive? Will the entire upper gear case fit?
I have read that 1985 had a manual or hydraulic assisted shift and the older drive has an electric shift.
In short my question is, what is the difference between a 1985 stringer drive and a mid 70's stringer drive?
Thanks for the info!
