Hi,<br />I have a Bayliner 1750 Capri Bowrider -87 with an Ford OMC Cobra 2.3L 4cyl ~130hp.<br />The engine is running without problem as long as You do not put any gear in.<br />The problem is att high rpm:s and during load, it feals that the engine is running on only 3 cyl (or even 2!?) and when I bring the speed down it dies immediately. I can then start again and it works fine at low speed and then the same again when I go for max...<br />I have checked the Sparc cables/plugs (new), ignition and the carburettor and can not find any faults.<br />Any suggestions please??
