Re: OMC Coupler fit
....I just had a thought....(it happens) <br /><br />Are you taling about the fit of the coupler to the shaft, or the shaft itself moving a little? The shaft rides through the gimble bearing and the bearing is designed to pivot, though it should take a little force to do it. If it's a little wobbly it might indicate the beginning of a possible problem with the bearing. <br /><br />I don't think mine had any "play", it would just move if I pushed it around, but would stay exactly wherever I put it.
