StillFishin'
- Mar 17, 2003
- 64
I have done a search on checking compression and it seems that the preferred way is to:<br /> 1. Disconnect plug wires.<br /> 2. Take out all plugs.<br /> 3. Hook the plug wires up to a spark tester.<br /> 4. Check compression one hole at a time with a screw in type tester.<br /> 5. All cylinders should be within 10% of each <br /> other.<br /><br /> Ok, so what it you don't have a spark tester? What would be wrong with using any of the following ways?<br /> <br /> A. Pull the kill switch and take out one plug at a time and crank it over. <br /> B. Pull the kill switch and take all the plugs out and crank it over.<br /> C. Take all the plugs out and reattach the plug wires to the plugs, let them hang and check compression one hole at a time.<br /><br />Obviously you don't want to just remove a plug and wire and crank as the engine may fire up so I didn't list that option.<br /><br />So to set my mine at easy I'd like to see what you have to say about the above, or if you have any other thoughts, please list them also. <br /><br />Thanks,<br />Stillfishin'
