I have a omc cobra 1991 4.3 lit.with holley 4 barrell card.First time out this season,it started fine ran wot fine cruised lake for a hour no misses or anything.We stopped,droped anchor for a couple hours,then it wouldn't start.<br />Cranked fine,just wounldn't fire.I first looked in carb to see if was pumping gas,it was,good spray.Checked choke,it was open and not binding.Still wouldn't start.The 2 switches monted on side of shift cable,side by side,one above and one below,I pushed in on the bottom one,small push button.I believe this is the ignition interrupt switch,and at the same time I also unscrewed the fuel water seperater filter part ways to see if fuel in it.Tried starting ,it started,thankful beings battery was getting run down.Question is any ideas on problem?Did these final things have nothing to do with it finally starting?I sure don't want to go through that again!
