WALKABOUT2
- Jan 10, 2003
- 1
Hi all and thanks in advance for your assistance. I have a 3.0 ltr 4 clndr, Cobra Out Drive, I think it is a 86 or 87. It wont hold in forward gear and "jumps out" when getting under load. I pulled the prop shaft, the Clutch Dog looked a litte worn, the gears looked "fair" and did show a little sign of wear but all in all not too bad. I thought a change of the clutch Dog would do the trick. It did not seem to help. I went trhough the book and I believe I have all the linkage in allignement.<br /><br />My question to the wise ones of this forum is this. Did OMC superceede the entire Clutch Dog into a replacement gear set? I had a hard time just fiding a clutch dog for this. Even if you disengage the lower shif cable and manually engage the forward gear it will still pull out under load. I believe I have eliminated everything in the shift linkage and shift shaft adjustment as a problem and feel the only thing left to do is put new gears and a new dog in it. Does anyone know if there has been shifting problems associated with the old gear sets in these old cobra out drives? <br /><br />Thanks
