OMC Cobra Trim and Tilt Problem
I have an OMC 350 5.0 motor w/ a cobra outdrive. The tilt and trim control switch moved the outdrive up and down fine last week. Now the tilt and trim switch doesn't move the outdrive. I can hear and feel the trim/tilt motor running...it makes a whining noise but the outdrive does not move up or down. Assuming the transom mounted tilt/trim system needs ATF fluid...? How do you check the system and refill to proper level? Any suggestions? Thanks
Bt Doctur
Re: OMC Cobra Trim and Tilt Problem
should show how in the manual. remove the fill plug and add oil.
